7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass),
105
Mod | | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85161 04/03/2003 8:02 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | My 67 burb seems to steel all the juice as soon as I try to crank her.. Shes got plenty on Off and some on ON but nothing on crank.. Suggestions? | | |
#85162 04/03/2003 8:11 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check and see if the connections at the battery and the starter as well as the ground wire are clean and tight. You may want to pull the battery cables off and make sure they are clean. The other thing I suggest is to have your battery load tested if the first checks do not work.
#85163 04/03/2003 8:14 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | Hi Thx for fast answer!
Already checked those two. The battery is new and the shoes are clean and tight!
Any more adwise? | | |
#85164 04/03/2003 8:17 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Does this happen when both cold and hot?
Look at the starter solenoid connection and starter mount bolts. - Do your battery cable ends have soldered connections or are they clamped onto the wire?
#85165 04/03/2003 8:20 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do you have a volt meter?
#85166 04/03/2003 9:21 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Welcome to the 'bolt, GM250. What part of Norway are you from? I spent a summer wandering the southern parts of Norway and Sweden; borrowed a buddy's car in Oslo and drove to the coast and back. Beautiful country full of really nice people. The beer is strong and the women are lovely; or was that the other way 'round? I agree that a volt/ohm meter will be helpful in chasing leaking electrons. My wild guess is there's a bad ground somewhere. Just for giggles, why not check the continuity of the starter itself; if the windings are damaged you could be dumping voltage through the starter housing. | | |
#85167 04/03/2003 10:12 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | Ive got a voltmeter inside the burb allright.. and it dumps down to way under 12 volts as soon as i turn the key.. I think it may be what we in Norway call "current regulator" (thas a direct translation), or perhaps the Generator.. Or as you guys mentioned, the starter.. Anyway, thanks for your help, and keep coming with good adwises!
and, btw, I'm an hour away from Oslo, the Capitol in Norway. | | |
#85168 04/03/2003 10:34 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Well from what I can gather, I would venture to say the starter and or starter solenoid(on top of the starter)has gone bad or you have a wire connection problem. The alternator/generator will NOT likely be the problem.
#85169 04/04/2003 3:52 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Check the across the battery and see what voltage you have when someone else cranks that motor, I have had batterys with bad bars between cells, if thats ok check the voltage at the starter when trying to crank, could also be the starter brushes to. | | |
#85170 04/04/2003 8:36 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Be sure you're well grounded. On my 69 I have a cable from battery to block, from battery to fender liner and from block to frame. Also check the cable connection from the battery cable (pos) to the starter terminal.
Fred 52 3600 69 C-10
