0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85140 11/24/2002 2:49 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Any one have a source for halogen lights for an 8 3/4 dia housing. I found a Hella rally light the right diameter but only in driving or fog light patterns. I have a 12 volt system with relays and heavy gauge wire all set to go.
TIA Steve Lemberg
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
#85141 11/24/2002 2:59 AM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Steve! This is an interesting site and may be what you are looking for. George. http://www.classicandvintagebulbs.com/ | | |
#85142 11/24/2002 6:01 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | George,
Thanks for the tip however, I am looking for a whole new reflector and lens for H-4 bulbs that will fit into my head light buckets. My cars all have 100/140 H-4 lights and I would like to ad these to my truck as well.
Steve Lemberg
#85143 12/05/2002 11:35 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Steve , 100 watts is nice but it's _way_ overkill - I drive out in the middle of nowhere , pitch black and my cheapo H3064 seal beams work just fine . go for it .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#85144 12/06/2002 1:45 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | Steve, buy a set of cheap H-4 headlights, cut out the lampholder and epoxy the piece onto the 8-3/4 inch reflectors .I did this and it worked. | | |
#85145 12/06/2002 3:16 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Nate,
I wouldn't use a sealed beam in any car or truck the light pattern is not very good. You are right about 100 watt being overkill in a sealed beam but not in a good H-4 reflector. The reflector in a sealed beam scatters light and higher wattage bulbs just make it worse. I have never been flashed by other drivers with my lights and my cars go fast enough to require good lighting. European e-code lights were designed to provide light that is very focused.
That said, the head lights are 8.75" diameter and the largest light assy are 7 inch. I don't want to put some small lights on the truck as they will look out of place.
Rust Bucket,
That is a great idea, I played around and soldered in some H-4 bulbs but my reflectors need to be re-silvered. I may try putting in a whole 7" reflector. Hella has some 8.75" reflectors for H-3 bulbs but they are only single beam.
Steve Lemberg
