4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#85140 11/24/2002 2:49 AM
Any one have a source for halogen lights for an 8 3/4 dia housing. I found a Hella rally light the right diameter but only in driving or fog light patterns. I have a 12 volt system with relays and heavy gauge wire all set to go.
TIA
Steve Lemberg
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck
1970 Mercedes 280SE 3.5 coupe
1987 Mercedes 560SEC supercharged
1989 Mercedes 300CE 5.0 M119
Steve!
This is an interesting site and may be what you are looking for.
George.
http://www.classicandvintagebulbs.com/
George,
Thanks for the tip however, I am looking for a whole new reflector and lens for H-4 bulbs that will fit into my head light buckets. My cars all have 100/140 H-4 lights and I would like to ad these to my truck as well.
Steve Lemberg
V
V Offline
Steve , 100 watts is nice but it's _way_ overkill
- I drive out in the middle of nowhere , pitch black and my cheapo H3064 seal beams work just fine . go for it .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
knuckle head
knuckle head
Steve, buy a set of cheap H-4 headlights, cut out the lampholder and epoxy the piece onto the 8-3/4 inch reflectors .I did this and it worked.
Nate,
I wouldn't use a sealed beam in any car or truck the light pattern is not very good. You are right about 100 watt being overkill in a sealed beam but not in a good H-4 reflector. The reflector in a sealed beam scatters light and higher wattage bulbs just make it worse. I have never been flashed by other drivers with my lights and my cars go fast enough to require good lighting. European e-code lights were designed to provide light that is very focused.
That said, the head lights are 8.75" diameter and the largest light assy are 7 inch. I don't want to put some small lights on the truck as they will look out of place.
Rust Bucket,
That is a great idea, I played around and soldered in some H-4 bulbs but my reflectors need to be re-silvered. I may try putting in a whole 7" reflector. Hella has some 8.75" reflectors for H-3 bulbs but they are only single beam.
Steve Lemberg
