| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | In a couple of stretches of interstate around here they have installed grooved concrete pavement. When I drive on this pavement my steering seems unstable. The truck wants to dart left or right and I have to stay really on top of it.
On smooth asphalt or concrete I can take my hands off the wheel and she tracks straight as an arrow.
I have stock suspension in this '51 1/2 ton with 6.50x16 bias ply tires with good tread.
Curious to know if anyone else has experienced this, and what if anything to do about it?
Kurt | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I have had the same problem with bias ply tires. I used to drive a 79 ford and I put bias plies on the front and radials on the back (I was broke). The truck was scary. It would shoot off into the other lane with no notice whatsoever. I changed the tires as soon as I could raise the money.
Gene 1959 Apache
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have found that with the old bias ply tires that by increasing the air pressure it helps some. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | one of the many reasons radials replaced bias ply tires, and one of many reasons anyone that actually uses an old truck on the road should switch
Bill | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | So I take it that I'm not the only one who has experienced this problem when driving on gooved pavement with bias ply tires? It seems like it is a common occurance?
I was concerned that this my be a symtom of some problem with the steering, but it sounds like tires....
Guess I'll start saving up for those Coker 6.50 x 16 radials I've been coveting...
Kurt | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Have you checked your toe-in?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Sweet,
Yes. Alignment is good and recently checked.
Kurt | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | adding more caster, helps, wedge shims between the leafs and axle | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Its a typical situation with bias-ply tires. I have new 650-16s on my 49 and it wanders but it does not flat spot, even after sitting for a month. Radials sound nice but when I bought a set (215-85R16) two dealers would not install them as my rims were too narrow. They said I need a 6" rim. So I bought Firestone bias-ply and am very happy with them. | | |
