5 members (TUTS 59, wilbur53, Jon G, Gdads51, 1 invisible), 85 guests, and 1 robot.
Topics128,131
Posts1,056,373
Members48,441
#849410 05/07/2012 5:31 AM
SO I WANNA SWAO OUT THE TORQUE TUBE ON MY 53 1/2 TON BURB AND FOUND A GUY WITH WHAT IM ASSUMING ARE A 318 AND A 319 ( HE SAID HE HAS 2 55-57 3 SPEEDS, ONE WITH O.D. THE OTHER WITHOUT) ARE THE GEARS INTERCHANGEABLE, I MEAN I WANNA GET AND USE THE O.D. TRANS, SHOULD I GET THE OTHER 3SPEED FOR PARTS? THANKS
The internal transmission parts are the same for the OD and non OD trans. If the price is right get both. You can usually buy the SM318 transmissions pretty cheap but if you have to buy individual parts some can be quite pricy.
Fred
so i pick em both up, 25 for the 3 speed and 50 for the 319 with overdrive. the 319 w.o.d. dosent seem to roll as smooth as the 3 speed without overdrive, can i just swat the rears of the two or should i take them to a trans guy and have him rebuild the 319.
The cases are specific to each other, there are differences in the castings on the main case of the overdrive version for the blocker pin and oiling passeges. There is also a difference in the mainshaft, the overdrive version is much shorter.
Bill Burmeister
