0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | SO I WANNA SWAO OUT THE TORQUE TUBE ON MY 53 1/2 TON BURB AND FOUND A GUY WITH WHAT IM ASSUMING ARE A 318 AND A 319 ( HE SAID HE HAS 2 55-57 3 SPEEDS, ONE WITH O.D. THE OTHER WITHOUT) ARE THE GEARS INTERCHANGEABLE, I MEAN I WANNA GET AND USE THE O.D. TRANS, SHOULD I GET THE OTHER 3SPEED FOR PARTS? THANKS | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The internal transmission parts are the same for the OD and non OD trans. If the price is right get both. You can usually buy the SM318 transmissions pretty cheap but if you have to buy individual parts some can be quite pricy. Fred
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | so i pick em both up, 25 for the 3 speed and 50 for the 319 with overdrive. the 319 w.o.d. dosent seem to roll as smooth as the 3 speed without overdrive, can i just swat the rears of the two or should i take them to a trans guy and have him rebuild the 319. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The cases are specific to each other, there are differences in the castings on the main case of the overdrive version for the blocker pin and oiling passeges. There is also a difference in the mainshaft, the overdrive version is much shorter.
Bill Burmeister | | |
