7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna), 140 guests, and 4 robots.
Topics128,204
Posts1,057,294
Members48,467
Was an Eaton rear axle standard equipment in a 1948 Chevy 4400 series dump truck? The axle shafts have 10 splines and 21 teeth on the outer end.
I replied with this on the oldgmctrucks.com site.
No. I don't believe the name for the single speed rear really had any designation other than being called a GM single speed rearend.
I also don't believe all the 2 speeds are even Eatons, although they can share some parts.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Hi rustednuts, Thanks for the reply. wbrowne
I'm not aware of any Eaton Rear Axles being factory installed by Chevrolet prior to 1956 when they introduced the 9000 and 10000 Series (2-1/2 ton) trucks.
I'm also not aware of any shared parts between Corporate GM and Eaton Rears...maybe a bearing or seal?
Both GM and Eaton made Single and 2-Speed rears...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Before 1956, the 2 speed rear axles in Chevrolet's were Timken rear axles. Eaton 2 spd. rears, were available in GMC's much earlier.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks Spanky, I didn't know that!
I knew GMC started using Eaton's way before Chevrolet did...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Yeah Mike, I recently removed a Timken 2 spd. from a '55 1st series Chevy COE that I parted out. Had it, along with the axles sitting in my moms back yard. Would you believe someone came along, & stole it out of her fenced back yard.
Spanky Hardy
1950 GMC 250 1-Ton
That takes a lot of nerve. Ya think they knew what it was or was it taken cause scrap is so high?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I don't know Mike. They took the differential, but left the axle shafts, & two junk SM420 transmissions, that were next to it.
Spanky Hardy
1950 GMC 250 1-Ton
