10 members (KEVINSKI, Goach2, 55shaker, Maybellene, Gray_Ghost, Guitplayer, Peggy M, 60steve, GradyB, Jeff Ogden), 128 guests, and 3 robots.
Topics128,204
Posts1,057,297
Members48,467
Hello,
I'm trying to find out what is written on the Red Tag On Back Of 1946 Fuel Gauge.
I have this much of the puzzle:
_______?_______ contacts this terminal it may burn out tank unit.
Can any one fill in the missing words at the beginning?
Harold
Harold
Generally, the warning is "Do not connect battery voltage". The tank unit is a variable resistor connected to ground, and if it's at its low resistance end from the fuel level in the tank, the short to ground will burn out the resistor.
It could also say "Do not connect a jumper wire to both terminals" which is basically the same thing- - - -battery voltage directly to the resistor.
Harold, some of the vendor sell those tags. You may want to also look and see what they say....
Here is a pic from an advanced design truck
....big red pic...
Looks like the wording is not the same as your year, might help, might not
Yours might read
If hot wire contacts this terminal...
Alvin,
I have looked at all the vendors I know of & cannot find this tag. Do you know which one?
Harold
Harold
Dad,
Thanks.
I believe I can use 3 of the words from your tag to fill in my blanks.
I'm guessing If Hot Wire contacts this terminal it may burn out tank unit.
Thanks for sharring.
Harold
Harold
Harold, I got mine from either JC or Classic Parts. Its up an under my dash now smile
Alvin,
Since I was able to piece the words together I made some. See attached photo.
http://s1117.photobucket.com/albums/k583/harold146/Parts/?action=view&current=GasGaugeRedTag.jpg
Warning Tag on Rear of Gas Gauge Terminal that Goes to the Sending Unit. This one is for a 1946. Other years may differ.
Short tag is a portion of the original.
I think it came out pretty close to original.
Harold
Harold
Hey hey, nice job Harold. (say hello to Billie)
