0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Hello, I'm trying to find out what is written on the Red Tag On Back Of 1946 Fuel Gauge. I have this much of the puzzle: _______?_______ contacts this terminal it may burn out tank unit. Can any one fill in the missing words at the beginning? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Generally, the warning is "Do not connect battery voltage". The tank unit is a variable resistor connected to ground, and if it's at its low resistance end from the fuel level in the tank, the short to ground will burn out the resistor.
It could also say "Do not connect a jumper wire to both terminals" which is basically the same thing- - - -battery voltage directly to the resistor. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Harold, some of the vendor sell those tags. You may want to also look and see what they say.... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is a pic from an advanced design truck ....big red pic... Looks like the wording is not the same as your year, might help, might not Yours might read If hot wire contacts this terminal... | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Alvin, I have looked at all the vendors I know of & cannot find this tag. Do you know which one? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Dad, Thanks. I believe I can use 3 of the words from your tag to fill in my blanks. I'm guessing If Hot Wire contacts this terminal it may burn out tank unit. Thanks for sharring. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Harold, I got mine from either JC or Classic Parts. Its up an under my dash now  | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Alvin, Since I was able to piece the words together I made some. See attached photo. http://s1117.photobucket.com/albums/k583/harold146/Parts/?action=view¤t=GasGaugeRedTag.jpg Warning Tag on Rear of Gas Gauge Terminal that Goes to the Sending Unit. This one is for a 1946. Other years may differ. Short tag is a portion of the original. I think it came out pretty close to original. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hey hey, nice job Harold. (say hello to Billie) | | |
