1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
Hi does anyone know where I can find new replacement and rear brake flexi hoses and 2 new emergency brake cables for a 46 2 ton??? Many thanks Matt
3B Offline
Hy matt d, the Raybestos p/n for the rear brake hose is BH4497, I can't help you with the brake cables, sorry.
Antique Auto Supply out of Texas had the Brake Cables for my 38 not sure what the differences would be from 38 to 46.
I ordered that part number and got a hose which has a much smaller diameter than the original one on my truck.
How do I get the larger diameter hose?
You could always try taking the hose to a shop that makes hoses and they should be able to replicate it. I have 1 shop here in town that does it and one north of me on my way to work. That's probably what I'll end up doing.
1956 Chevy School Bus Superior Body
good suggestion, I was going to try these guys
http://brake-hose.com/
3B Offline
Hy Jay_Brown, I'm sorry if the hose p/n I quoted did not match the hose that was on your truck, it has been 66 years since a 1946 truck was built, and myself and others can only quote the numbers that the parts books tell us were the original equipment on the truck in question. I don't think any of us can tell how many times a given truck is worked on, and possibly modified from it's original design. I have used this same hose on a few of my trucks and others that I have worked on for other people, with no fitment issues. If you would like to tell us the length of the hose in question, and what the threads are that are on the line you're trying to replace, I will do my best to find a p/n which matches your specifications.
length is perfect
fittings on both ends are perfect
just the diameter of the orifice in the fittings is smaller than the original. the hose is smaller in diameter too.
so it would bolt up no problem but not as much fluid will flow
just take your old hose to napa they can match it up to a similar one. Thats how i got mine, its the same hose but 1/2" longer.
