4 members (Forty9, dt235sd, Dennys28, dwreills), 44 guests, and 3 robots.
Topics128,042
Posts1,055,518
Members48,424
#84901 11/03/2004 3:16 PM
My "new" 64 has idiot lights. Sometimes the "hot" light will flash on while cranking, but I have never seen the cold light come on even after a bulb swap. Is it supposed to come on while the engine is "cold"? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#84902 11/03/2004 3:24 PM
it does not come on EVER and say cold. If it ever does you have a ULO ...unidentified light object
#84903 11/03/2004 11:25 PM
Riding in the Passing Lane
You should have 2 terminals on the sending unit.
Ground 1 wire at a time & the coresponding light
should come on with the key on. If the cold
light comes on replace the sending unit. The
hot light should come on with key in start
position. I like to put in a new sending unit
anytime I get a "new" vehicle just too be shure.
smile
1972 Chevy c10 Cheyenne Super
#84904 11/04/2004 1:42 AM
Brian.I Had the same problem...Replaced the sending unit, problem solved
1965 C-10 Stepside
#84905 11/04/2004 6:57 AM
So... what's the purpose of a "cold" light? Is it a reminder for drivers of trucks with manual chokes?
Gord
1954 1/2 ton 235 4 speed
#84906 11/04/2004 5:41 PM
Not sure on function. Both lights will work when grounded at the sender. I will have a new sender tomorrow. Brian
#84907 11/05/2004 8:00 PM
Replaced the sender, no change. Wonder how cold is "cold"? Brian
#84908 11/06/2004 10:30 PM
It should come on anytime the engine has cooled
down. It lets you know when you can turn the heater on. smile
#84909 11/07/2004 4:48 AM
Found a bad connection, had corrosion between the terminal & wire. Replaced the terminal, now it works. Pretty cool! Brian
#84910 11/11/2004 5:07 PM
looking back over the post I must have been coin-fused over something?? maybe I "thought" he said 54 instead of 64?? if you have a light on a 54 its a ULO.......i plead guilty. Cuff me and take me away. No one listens to anything I say anyway...or at least not the lady of the house!!
#84911 11/11/2004 6:13 PM
I kinda wondered, but thought maybe you meant they would never work correctly. Brian
