0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#848916 05/04/2012 9:24 PM
Y
Y Offline
OK, I've changed my 53 AD to an open driveline, saginaw 4spd with a truck rearend. I've had driveshafts made up for all the different applications, when I had the 6 cyl, then when I put in the 350 ect. So I've got different size u-joints and yokes. My question is, if I can find the right "cross" can I mate up any driveshaft with the camaro and or my S-10 rearends?
ODSS Lawman
ODSS Lawman
The cross you are referring to is called a trunion. I would thing if you went to a local FLAPS with both ends of the u-joint you can find a match.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Commonly called a "staggered" U-joint. They can be longer one way than the other with the same size needle bearing cups, same with different size cups, longer one way with different cups, just about any combo one needs.
Evan
Evan
