| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 37 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 37 | I have a 47 3100 that I am putting a 54 235 in place of the broken 216. My plain is to do the Patrick's set-up using the Saginaw 4 speed. I found a two groove input shaft saginaw but the bell housing off my 216 does not mate up with this 4 speed. It is about 3/4" from the holes matching. The guy that has the saginaw says it is form a late 60's vette. It does have the 2 grooves. My question is are there other two groove saginaws or is my 47 bellhousing diffrent than the other year AD bellhousings? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Corvettes did not come with a Saginaw 4 speed. | | | | | Joined: Nov 2011 Posts: 37 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 37 | I did not think they did but he did have two vetts setting there a 68 and a 69. And he has two of these saginaw 2 groove trannies. Maybe diden't come in the vette but was a cheep replacment. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy kswillie, I believe 1947 was the last year for the sliding gear four speed transmission, and the older design three speed, both these transmissions had a smaller bolt pattern than the newer transmissions. In one way you're lucky, your 47 doesn't have the clutch and brake pedals mounted to the bellhousing, so you could use a 48 - 53 bellhousing, and everything should work perfectly, hope that helps. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | 3B's advice is spot on. '47 was the last year for the non-synchronized transmissions which have a different bolt pattern than '48 and later.
Jeff | | |
