1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Hoping someone can help me out. I have been looking at ordering tires for my truck.
I have 4.5" rims on the front of my 36, and I know that you can fit 600-20 tires on them but I am hoping to run 550-20 tires. The 600-20's cross sectional width is 6.3" where the 550-20 is 5.9" The main reason I want to go with the 550 rather than the 600 is that they are 4 ply versus 6.My truck will never see any sort of load carrying, and I have been told that 4 ply will ride far nicer than a 6....
I emailed Coker with this question and his response was less than helpful, "it will probably work but I wont guarantee it will"
any thoughts???
Thanks guys | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Springs on 36 models were pretty stiff. You won't see much ride improvement with 4 ply versus 6 ply. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 |
| | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | | | | | | Joined: Jan 2010 Posts: 37 New Guy | | New Guy Joined: Jan 2010 Posts: 37 | I love the truck!
What axle ratio are you running? | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Thanks man,
It is a Dana 61 with 3.07:1 it's a custom job I made by merging it to the original axle | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | | | | | | Joined: Jul 2008 Posts: 115 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 115 | My response must first start with a question. In 1936 there was technically no 4.5" wide truck rim made. So we need to know how you've measured your rim width. The standard of measurement back then, according to period National Wheel and Rim Association (NWRA) catalogs, was to measure across the rim lips. In 1936 Chevy listed wheels that were 20" x 5", and 20" x 6". These rims, however, when measured using the revised NWRA standard that came into use in the 1940s measure 3.75" and 4.33" respectively. This measurement is taken across the inner rim base. I have Goodyear charts from the era that show a 5.50" tire would be correct for a 5"(3.75") rim, but would not be correct for a 6" (4.33") rim. They show the correct tire to be either a 7.00" or 7.50" on the 6" (4.33") rim. I know I have later references that show use of a 6.50" tire on the 4.33" rim, but don't recall any showing use of the 6.00" tire (much less 5.50") on that rim.
Edit - I found a 1944 Budd reference that shows use of the 6.00" tire on the 4.33" rim. Stu McMillan
| | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | Boy I'm glad you are blazing the trail for me on this truck. Have you considered all of the types of wheels that would fit on those Tahoe disks? If the disks fit over the original hubs, maybe there are some rat looking wheels that will take a better tire. BTW, I love your truck and the innovations that you are putting into it. bob | | | | | Joined: Jan 2010 Posts: 37 New Guy | | New Guy Joined: Jan 2010 Posts: 37 | IMHO, those wheels make the truck. Did you install new outers on some OG centers?
4ply should ride softer than the 6 plies, but I have no idea how much better. | | | | | Joined: Jul 2008 Posts: 115 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 115 | Looking closely at your Photobucket pics, it's clear you have custom made one piece drop center rims up front. I didn't look that closely before my first reply, so your 4.5" statement is no doubt correct. I still think the 6.00" is the narrowest you'll want to go, but would suggest you check other sellers to ask the question. Places like Universal Tire, M.E. Miller, and Lucas Tire may be able to give an answer. Stu | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | My response must first start with a question. In 1936 there was technically no 4.5" wide truck rim made. So we need to know how you've measured your rim width. The standard of measurement back then, according to period National Wheel and Rim Association (NWRA) catalogs, was to measure across the rim lips. In 1936 Chevy listed wheels that were 20" x 5", and 20" x 6". These rims, however, when measured using the revised NWRA standard that came into use in the 1940s measure 3.75" and 4.33" respectively. This measurement is taken across the inner rim base. I have Goodyear charts from the era that show a 5.50" tire would be correct for a 5"(3.75") rim, but would not be correct for a 6" (4.33") rim. They show the correct tire to be either a 7.00" or 7.50" on the 6" (4.33") rim. I know I have later references that show use of a 6.50" tire on the 4.33" rim, but don't recall any showing use of the 6.00" tire (much less 5.50") on that rim.
Edit - I found a 1944 Budd reference that shows use of the 6.00" tire on the 4.33" rim. Stu McMillan Stu, you are correct my referring to a 4.5" rim is in reference to the inside dimension, the outside dimension across the outside lips of the rim is 5 7/16" I appreciate your input... I think I need to do more research. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Boy I'm glad you are blazing the trail for me on this truck. Have you considered all of the types of wheels that would fit on those Tahoe disks? If the disks fit over the original hubs, maybe there are some rat looking wheels that will take a better tire. BTW, I love your truck and the innovations that you are putting into it. bob Bob, the tahoe disks are mounted to the inside mounting pattern, where the original drums mounted. Couldn't mount rims there if I wanted. Plus I really wanted to maintain the original look | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | IMHO, those wheels make the truck. Did you install new outers on some OG centers?
4ply should ride softer than the 6 plies, but I have no idea how much better. Yes, that is exactly what I did, I did a thread on how I did it a while back | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Looking closely at your Photobucket pics, it's clear you have custom made one piece drop center rims up front. I didn't look that closely before my first reply, so your 4.5" statement is no doubt correct. I still think the 6.00" is the narrowest you'll want to go, but would suggest you check other sellers to ask the question. Places like Universal Tire, M.E. Miller, and Lucas Tire may be able to give an answer. Stu I will double check with other tire vendors, what has thrown me on this whole thing Is I have spoken with a few different people at coker (coker made the drop center blanks) and I haven't gotten the same answer I read a build where a guy built a hot rod with these same wheel blanks and he said he had 550 in the front and 700's out back, but when I sat down to order my tires the fitment chart at coker says that both the 550 and 600 should be on 3" rims. This was odd to me because I know I pulled 6" tires off the original rims, which these blanks are as close to those as possible. Thanks again for your help, I will let you guys know what I end up doing. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | well guys, I ended up going with the 550-20s for the front of my truck... fit just fine on the 4.5" rims. I will post up some photos shortly..
Thanks for everyone's input | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Looking forward to seeing the new pics. Normally not a ratrod kind of guy, but that is pretty sweet with the open duals in the back. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Looking forward to seeing the new pics. Normally not a ratrod kind of guy, but that is pretty sweet with the open duals in the back. I posted them here https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=847387#Post847387I like to think of it as more of a big hot rod than a rat.. just because rat rods are becoming more and more known for poor fabrication and gimmicky add ons.. skulls/iron crosses/spider webs/tractor grills.. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Looks real mean!  | | |
