6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
This may be a very simple question for many but I just installed the engine into my 54 and bolting up the Powerglide but I need to turn the engine to get all of the flywheel bolts installed. This requires turning the engine.
Is there a particulr tool perhaps to use at the harmonic balancer or what have most of you done before for this???
On my 270 I just put a socket on the crank bolt. It helps to have the spark plugs out, then you might even get away with turning the fan blades...
Give me ambiguity
or give me something else
I made a tool.
It looks like This
There are a couple views there.
Hope that helps,
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
I may have missed it. Is your engine an L6?
I had a similar problem with my clutch pressure plate installation with the bell housing mounted on the 261.
On mine, I finger tightened all the bolts and then tightened one then using it to rotate the engine to get to the next.
Thanks for everyone's advice
CASO - I am working on a 235 and could not see where I could use a socket on the harmonic balancer to turn it. The center hole is not threaded. Must be a differnce in the 2 engines perhaps?
LOSTMY47 - thanks for the photos - that is the type of tool or device I need it appears. This is what I may need to fabricate. I should check with my rebuilder to see if he has one of these for a short term borrow.
HELLONMRWILSON - yes I have very liminted access to slip the bolt in the housing through the flywheel to the torque converter. Got the first one in and then I need to spin the motor to get to the next bolt hole and so on for the other 5.
The shop manual did not say anything of this but I should check again....
John Lanning
