| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I had to replace my front u joint today.It had been vibrating off and on for a while but the u joints seemed tight every time I checked them. I finally found some play in the front one today so I just went ahead and replaced the rear one too. When I was checking them I noticed that there was a little up and down play in the tail shaft of the 3 speed transmission.It was also hot. It is not a lot of play and not so hot that you can't grab ahold of it. The drive line that goes into the transmission is also hot after going down the highway. I have never felt it after driving it before so I don't know if this is normal or not. The seal has been leaking since I put the transmission in a few weeks ago but the u joints did seem to fix the vibrating problems. Are the bearings bad in the back of my transmission or is this normal? Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | What type of drivetrain? Open or closed? If closed, are you putting gear oil in the ball the u joint goes in? It need about a pint of gear oil to stay happy.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | It is an open drive line on a '59 Apache.
Gene 1959 Apache
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | You will have a little play in the tail shaft. Remember, there is an input shaft going into the transmission supported by one bearing and likely floating on needle bearings where it connects to the tail shaft which is also supported by only one bearing.
A little play is okay, a lot isn't.
Jeff | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | How about the temperature?
Gene 1959 Apache
