1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Anyone running a Hurst 3 speed shifter on the floor? I'm thinking about putting one in my 49 3600 with a later three speed (SM318).
I'm wondering about length of shifter and clearing the bench. Apparently they made these up to 18" long..
Any thoughts appreciated. I may even stick with column shift. Just looking at options. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I think the 18" should be great, had one in my 46 for a while. That was with a saginaw 4 speed, had to modify the mount to the trans and shorten the rods to move it forward and clear the seat. Since that trany I've stepped up to the S-10 T-5, comes with it's own shifter which is centered in the truck and with the old narrow 46 it made a huge improvement. Best of luck | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Hey thanks appreciate it!
Nice looking 46 by the way. The old man had one - paid $750 for it after trading in a 51 sedan delivery many moons ago. | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I just went down to measure mine, 21" to the Hurst "T" handle, same hight as my thigh, extremely comfortable. I didn't know if I'd care for a "T" handle but I love it on my dd only vehicle '49 1/2 ton.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | thanks Cosmo...so I take it yours works ok and you are happy with it?...
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Randy, It's a B+M shifter, on a '62 3sp+od trans. with non-synchro first. I made my own 'up-over-up' to center the shifter in the floor on a home-made bracket. I had to bend the shift rods in order to clear the solenoid. I also made my own shifter dogs to shorten the overall throw and stick welded them to the trans.
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Very nice..I'm planning to put a 55-57 3 speed with OD in the 49 3600 with 4:10 rear..I managed to find a guy with a Hurst GM 55-57OD mounting kit NOS and a 18" shifter - the linkage is pre-bent on the kit and the brackets are designed to clear the solenoid.
I gotta fix the OD, a few parts are busted on it. A spare parts tranny would probably be best. And I need a kickdown switch. Worth the trouble tho I think - these trannys are pretty neat.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have an extra kickdown switch if you need it.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | |
