| | | Forums66 Topics128,022 Posts1,055,360 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have just under 200 miles on the rebuild and I think it's about time to do the 'final' lash set. I bought a Zim wrench and am thinking of setting the lash while the engine is running. I've always done a static set in the past so setting a running engine is new to me. Is it done by ear or do you use a feeler gauge? If it's done with a feeler gauge where do you grow the necessary third hand???  The tech tips only address a static set.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I've always done this bit of fine-tuning by ear. I like the interaction with the engine! | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Here's what I do.. Get engine hot. Hot.. Up to engine temp. Box wrench on the nut screwdriver in hand, loosen the nut leaving it on the nut as I put the screwdriver into the slot. Pick up your feeler gauge, check lash, hold screwdriver in place and tighten the nut. takes some practice I reckon. And it kicks a bit of oil about. Robert's your mother's brother... Piece of cake...
Jeremy | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | When I've adjusted lash on a running engine I use a stepped feeler gauge. I'm not looking for perfection on a daily driver, so a stepped gauge works just fine. The step on my KD feeler gauges is .002. IF the gauge slips through the valve, and rocker, but won't go pass the step, your close enough. IMO
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Tiny, By using the Zim wrench you can hold the feeler gauge in one hand and use the other to hold and turn the wrench. You use your thumb to turn the adjusting screw while the rest of your hand hold the wrench. I've got a Snap On wrench that is similar to yours that I use. It does take a bit of practice, you need to have a limp wrist to make it work. With the idle turned down low it will still want to bounce your tool and hand of the rocker arm. Once you get the feel it will be easy. At first you will think its crazy. Good Luck Don | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | The nice thing about doing it with the engine running is if you have a loud one, you'll know it as soon as you get the feeler gauge in there. All of a sudden the noise will go away.
1956 Chevy 3200
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Tiny, do you have hydraulic or solid lifters?
I always thought adjusting this way while running with solid lifters was a no-no.
Jeff | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Doing any sort of running adjustment is less than effective, but trying it on hydraulics can be particularly frustrating. Getting slapped by the cam lobe several times a second means that the lifter never gets the chance to top itself out fully, so the adjustment is always a SWAG. Engine stopped is the way to go, solid or hydraulic! Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | With the engine running was the only way we did it way back. I've got mashed out feeler gauges to show for it. The only good way is with the engine off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I believe the manual for my 218 flathead recommends adjusting the valves with the engine running. But a machinist did tell me that it wasn't a good way to do it. Hm.
1956 Chevy 3200
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have just under 200 miles on the rebuild and I think it's about time to do the 'final' lash set. I bought a Zim wrench and am thinking of setting the lash while the engine is running. I've always done a static set in the past so setting a running engine is new to me. Is it done by ear or do you use a feeler gauge? If it's done with a feeler gauge where do you grow the necessary third hand???  The tech tips only address a static set. Tiny, What is the Zim wrench for? I've never seen anything like it.
~Jim
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What is the Zim wrench for? I've never seen anything like it. ...click... ...click... I would like to see a video of someone setting the lash with the engine running. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I would like to see a video of someone setting the lash with the engine running. I would too. I've heard of a lot of people who've done it but I never have. I thought it might be fun to try. Back in the day when I was just a puppy I remember the mechanics mentioning that setting lash on a running engine was the best way. Many said they did it by ear rather than use a feeler gauge as well. In a worst case scenario if I can't master the wrist timing I'll just shut it off and do it the way I always have.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | When we were just high school kids we wore out the feeler gauge setting the lash. I would be afraid to try to set it by ear. If the valves are anything like the old VW Beatles, too tight meant burning the valves. At least that's what I've always heard.
~Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I was taught by a few good old boys (back in 1969) to set the valves with engine running. What a pain and what a mess. Now, I only do the static adjustment technique. This could not be much simpler: after finding #1 at TDC and setting half of the valves, you just rotate the crankshaft 360 degrees and then set the other half of the valves. I bought an old Zim valve adjuster a few years ago and the job is now a little easier. The Zim tool shows up regularly on eBay. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have an old setup called a Valve Gapper. It sets on top the valve & has a dial indicator that gives the amount of clearance. I have not used it for 50 years. When I started working on Cummins Diesels I found out how much better it is to do it statically. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
