1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#847811 04/30/2012 2:34 PM
In a couple of stretches of interstate around here they have installed grooved concrete pavement. When I drive on this pavement my steering seems unstable. The truck wants to dart left or right and I have to stay really on top of it.
On smooth asphalt or concrete I can take my hands off the wheel and she tracks straight as an arrow.
I have stock suspension in this '51 1/2 ton with 6.50x16 bias ply tires with good tread.
Curious to know if anyone else has experienced this, and what if anything to do about it?
Kurt
I have had the same problem with bias ply tires. I used to drive a 79 ford and I put bias plies on the front and radials on the back (I was broke). The truck was scary. It would shoot off into the other lane with no notice whatsoever. I changed the tires as soon as I could raise the money.
Gene
1959 Apache
I have found that with the old bias ply tires that by increasing the air pressure it helps some.
one of the many reasons radials replaced bias ply tires, and one of many reasons anyone that actually uses an old truck on the road should switch
So I take it that I'm not the only one who has experienced this problem when driving on gooved pavement with bias ply tires? It seems like it is a common occurance?
I was concerned that this my be a symtom of some problem with the steering, but it sounds like tires....
Guess I'll start saving up for those Coker 6.50 x 16 radials I've been coveting...
Kurt
ODSS Lawman
ODSS Lawman
Have you checked your toe-in?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet,
Yes. Alignment is good and recently checked.
Kurt
adding more caster, helps, wedge shims between the leafs and axle
1949 SUBURBAN
Its a typical situation with bias-ply tires. I have new 650-16s on my 49 and it wanders but it does not flat spot, even after sitting for a month. Radials sound nice but when I bought a set (215-85R16) two dealers would not install them as my rims were too narrow. They said I need a 6" rim. So I bought Firestone bias-ply and am very happy with them.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
