Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#84753 10/25/2007 4:21 PM
Hi all,
I'm in the process of putting in a new engine in my '65 and while doing so, switched out the floor shift for an automatic column. I'm having a bugger of a time figuring out how to hook up the automatic column shifter to the TH-350 transmission. Any help is appreciated.
#84754 10/25/2007 6:10 PM
I used all the linkage from a 1980 C10
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#84755 10/25/2007 7:08 PM
Did you have to do any cutting, welding, or other modifications, and did you also use the power steering unit from the S-10? I'm also thinking about adding power steering.
#84756 10/25/2007 7:16 PM
That's a C-10, a half-ton truck, yes I robbed the steering box also. It's been a while, but I just took the linkage, spring, trans piece, bushing & frame bracket & all & it worked fine, had to drill 2 holes in the upper flange of the frame using a right angle drill for the little bracket to mount.
#84757 10/25/2007 7:46 PM
thanks '64. I'm gonna check out our local salvage yard and see what I can find. I checked out your photobucket too. Nice!
#84758 10/25/2007 8:45 PM
Thanks, the two kids have put the brakes on my projects lately,,maybe someday they will get done.
#84759 10/25/2007 10:01 PM
Riding in the Passing Lane
There is a universale link kit avaiable that is adjustable. I think Summit has it & yogis also.
1972 Chevy c10 Cheyenne Super
#84760 10/25/2007 10:26 PM
'64, I know, I have two of my own (one and three years old). My truck will always be a "work in progress".
'wrench, I bought one from Lockar but it only seems to have about half of what I needed. I thnk it was the half from the tranny, but it didn't come with instructions so I'm kind guessing. I spoke to a guy at our salvage yard today and he's checking his yard for me.
Thanks again
#84761 10/26/2007 3:10 PM
Junior Member
Junior Member
If you get the lokar cable, you also have to get the aluminum piece that clamps on to the bottom of the steering column. I think the part no. is ACA-1804. That will hold the cable. The Lokar kit is kinda pricey. I am using that kit on one of my trucks, but I'm with '64, I'd try to use '80's linkage
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
thanks guys,
I found a donor unit out of a '74 Chevy with a 3spd auto. I haven't installed it yet but it looks like it will work alright.
