1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#847181 04/27/2012 11:53 PM
I decided to install my front window in my 46 using black urethane. I started out with gloves but the stuff was so sticking they weren't working so I took them off. By the time I was done my right hand was covered and my left hand was far behind. Guess what, it doesn't come off. I tried gas, laquer thinner, comet, goo b gone, vegetable oil, various soaps, bascially all my typical tricks, nothing works. I'm an insurance agent and my hands look like I've been working on cars all day. Everyone at works thinks it's pretty funny.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Heh. That is kinda funny. wink
I've always layered up a couple pairs of surgical gloves (so you can peel them off layer by layer) and worked with popsicle sticks and tooth pics when using adhesives like that.
Thanks for the warning. Try LAVA hand soap. Hope those nasty chemicals don't do more than stain!!!!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
yard work
it'll take anything off your hands
even skin!!
1963 c10
Tincture of time.
Been there too many times.
Chuck
Same problem with "Gorilla Glue" (which I love)or just about any of the urethanes. It's not so much a stain as it literally turns your skin black. The only thing I have found that works are sandpaper...and waiting for the old skin to fall off & renew.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
green grass has oils that will help take it off
I like fixing stuff.
back yard wrench turner
W Online: Content
I had the same problem while gluing down hardwood floors. My hands would be black for days. Nothing I tried would remove the urethane glue.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Great minds think alike!
I use urethane in my day job,so I use the layered glove technique too.
Mind you the idea is to get the urethane on the vehicle,not your hands in the first place! lol.
For the occasions where I do get it on me I wipe straight away with paint shop wipes and use a pumice stone for the dried in stuff.
More pix on Flickr.
I just got through painting the Blue Funk's frame. I would apply skin oil to my face, wear latex gloves, AND THEN put on rubber gloves. I figured if the paint splatted on my face, the oil would prevent it from sticking to my skin.
However, I did not wear a hat. I was looking at my work after about an hour and a half of painting. I had everything put away and rubbed my hand over my head, On the back of my head was dried KBS paint. You know, the stuff that nothing will take off? You have to let it wear off.
Well, I got a mirror and looked in a mirror at the back of my head. Sure enough, there were 3 paint splatters. I musta dripped some paint while I was under the frame and then laid my head in the splatter.
I got my elecric hair clippers and gave myself a really really really short haircut. I was able to remve the paint after about 48 hours with some body oil and fingernails.
Yes they did.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
I got some of that epoxy you use to set bolts in concrete on my fingers the other day. It took 10 minutes of concentrated effort and hand cleaner to make it let go.
use lotion on your hands. it will help loosen the outer layer of skin. because urethane is intended to stick.
ZEP makes a product called "Glove" that you apply like lotion to your hands. you work it deeply into wrinkles and cracks and pretty much anything that gets on your hands washes off with soap and water. pretty good stuff.
Try a dremal tool for removing unwanted painted skin! Worked for me. I put some lotion on afterwords and you couldn't tell I had that stuff on me just a few minutes before.
Acetone plain old Acetone will remove it! The glove deal and body oil and or powder is a good thing. I steel get it on me so acetone.
