6 members (Otto Skorzeny, WICruiser, Paul_WNC, GRNHydra, Phak1, 1 invisible), 180 guests, and 14 robots.
Topics128,078
Posts1,056,039
Members48,433
#846933 04/27/2012 12:51 AM
Got my back up light mounted (Guide B-31), and a push/pull switch mounted to dash. Should I put a fuse in the circuit - and where (in the "hot" wire to switch, or between switch and lamp)? If a fuse is needed, what size or rating. I have a 6 volt system. Thanks in advance.
the factory accessory backup lites take a 9a fuse, so I'd think that'd be advisable - should go in the supply wire before the switch
Yep, I agree with Bill. And, love your truck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Thanks guys - wiring the light up without a fuse just seemed like "askin' fer trouble" - I will install an inline fuse as suggested. Thanks again.
A fuse needs to be able to carry enough current to power whatever item is being operated, and have a low enough capacity to protect the wire in case of a short. The bigger the wire, the bigger the fuse can be. A 16 gauge wire should have a 10 amp or smaller fuse, while a #12 wire can go up to a 15 amp, 20-25 amp for a #10, etc.
