5 members (1955 1 Series, CuzzFuzz, Forty9, Hotrod Lincoln, thekid1950), 51 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#846887 04/26/2012 9:15 PM
I have a kit for cab mounting, it includes 8 rubber bushings for the rear cab shackle two square rubber pieces for the front mounting bolts. However it came with 2 large metal washers about 1.5 inches in diameter and not sure what its purpose. Also can someone explain the shackle with installation method. I have a factory book which calls for .760 clearance between the floor panel and truck frame. any help is appreciated
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
blanch53 #846934 04/27/2012 12:57 AM
The washers go inside the cab on the front mounting bolts.
Don't know the shackle installation method.
Baba #847201 04/28/2012 1:02 AM
The cab shackles once you have them rebuilt can be shimmed see picture for how shims look. If you have not removed them the original shims will be there so you can see how they were arranged. Measure from the frame to the bottom of the cab in back you just need it level there once everything is tightened down.
http://good-times.webshots.com/photo/2235943390102454676FUuGUv
Shims can be on frame or cab bottom I have seen trucks with 6 and trucks with none. Lock plates go inside cab behind seat pan.
Brad Allen #847330 04/28/2012 4:24 PM
I tried to make the shimming easier by cutting wood blocks slightly thicker than the specified clearance. I could then easily determine how many shims to use, get the bolts started loosely, and then lifted the cab enough to slip my wood block out. Worked good for me.
Chuck
