0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
I was thinking about this question and wondered if you cleaned up the area around where the rivets are fastening the rim to the center mounting plate and applied J-B Weld around each rivet would you then have a tubeless tire rim? Possible or not? Or, could you carefully weld in this area to give yourself an air tight seal? Has anyone tried this before? Is there anyway to make this conversion?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Not sure but I would think the inner bead that holds the tire on a tubeless rim would have to be a bit larger.
i've done it and would not recommend it. it will work but not well.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
All 4 of the origional artillary wheels in my '41 are carring tubless tires with no problems, 3500 miles and two years so far.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
I've been running tubeless tires on my '50 for the last 3 years with no issues. I've heard of some guys using a sealer around the rivet heads.
H Online: Content
Try inflating a tubeless tire on the rim and use bubble soap to check for leaks around the rivets and bead area. I'd suggest sandblasting the inside of the rims and coating them with epoxy paint or fiberglass resin as a sealer if there are some seep leaks.
Jerry, do you think powder coating would seal those areas?
Jeff
My 1953 Chevrolet
1947.1 Gallery
H Online: Content
It's possible- - - -never tried that approach. We used to build up our own rims for dirt trackers and tractor pull trucks by cutting one flange off in a brake lathe, welding in an extension, and rewelding the flange. Of course, those wheeels only needed to hold air for a few hours, not months at a time. We epoxied the weld beads to seal up any pinholes and kept a close eye on the pressures- - - -usually in the 10-20 PSI range.
