0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Awhile back I was going through some old rims and noticed a few had some serious wear around the lug holes.
The rims are solid, straight and still useable, but obviously they have been well used over the years, distorting the lug holes probably due to over tightening and repeated on/off use.
I was curious if this can be fixed and how?
Thanks, Jeff | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I had a set in the same condition and saved them by replacing the 7/16 lugs with 1/2" ones. Required drilling 7/16 lug shoulder holes slightly larger. The tapered part on a 1/2" lug nut is considerably bigger and really big on some Lincolns. The nice thing is they have 7/16 lugs with the same shoulder size that presses into the hub/axle as the 1/2 has so it's easy to go back to the original size.
Evan
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If they are hub piloted, it doesn't make any difference. If they are stud piloted and the holes are wallowed out, they are junk. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thanks guys, that answers my question. They are stud piloted and I didn't know if anything could be done. The wheels are quite straight and solid, but some of the lug holes are pretty abused.
Maybe it's time to make an air compressor hose reel out of them!
Jeff | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | crenwelge is right, and you have the right idea. Put a nice hubcap on your hose reel!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
