7 members (NorCal52Suburban, Jay R, Chris's 46 / 515, dt235sd, Wayne67vert, Otto Skorzeny, 1 invisible), 68 guests, and 6 robots.
Topics128,172
Posts1,057,109
Members48,463
I drove my '52 28 miles home from storage a couple weeks ago and already know I want a higher gear ratio than the 6.13. I got it all the way up to 48 mph and the engine sounded like it was ready to come apart. I would like to get into a newer axle with standard 10 bolt budd wheels and hydraulic brakes. A ratio in the high 4's to low 5's would be good. Has anyone done this swap to recommend an axle that will match the spring width ?
1952 Chevrolet 6400 flat bed
How about a overdirve trans or a auxilary overdrive trans???? 1-262-392-2989 or [email protected]
Marv.
I did read about some people swapping in a newer 5 speed overdrive trans but that doesn't get me away from the hard to find wheels and tires.
That could still be an option, depending on what I find for gear ratios in a newer axle.
Crusing in the Passing Lane
There are previous comments in this subject; D 70 and 80 rear axles come w/ that bolt pattern(10 on 7.25), up to 3.56 and even 3.3 ratios w/ disc brakes. The hub is slightly larger, bore out wheels and cover plates if you have them, can use your 20" wheels; or can use 19.5" wheels(common), look too small on the truck though, or 22.5(hard to find) from '50's farm trucks.
For more details on Ed's info go to the "Tech Tips" tab at the top of the page, click it and you'll find these two tips on the subject under the "Big Truck" sub heading
http://www.stovebolt.com/techtips/bigbolts/p30swap/
http://www.stovebolt.com/techtips/wheels/
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I'm looking for expereince with something from the 80's, like an IH axle with ball seat wheels. Would like to get away from the hard to find wheels and tires.
---All pictures---
24601
24601
Wow, Grigg -- What a cool truck!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John you have watched Grigg enough to know if it's not cool when he gets it he will make it cool LOL thumbs_up
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
