Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (KEVINSKI, 68ironhead, 1 invisible), 103 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#845549 04/22/2012 12:08 AM
I have a 56 TF that I moved the tank to under the bed. Stainless steel gas lines run along the frame to the engine compartment. I have two brass in-line connectors that are leaking fuel. I've tighten both up, but still have less of a leak. So progress, but not the total solution.
Do these connectors require Teflon? Is there something I might be missing here? Gas eating through an o-ring...???
The garage is a bit randy with the smell of gas. Momma's tolerating it... for now.
Suggestions welcome.
Paul
1956 Chevy Task Force Webshots
My wife puts knots on my head faster than I can rub 'em. That's why I ask knot-headed questions.
skraps #845563 04/22/2012 1:32 AM
Check out Permatex - they have a sealant for fuel lines.
skraps #845579 04/22/2012 2:30 AM
are they compression or flare fittings?
....David
54barnfind #845603 04/22/2012 3:33 AM
A little more info, and we can help!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #846342 04/24/2012 9:10 PM
Not sure if there're compression or flare. Is there a way to tell without unscrewing the fittings? It would be a mess!
Paul
skraps #846370 04/24/2012 11:24 PM
If it's still leaking, you gotta take it apart anyway. grin
Are you from Colorado? Or is the truck from Colorado?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
skraps #846429 04/25/2012 3:49 AM
Is this the fitting - from your online albumn - or is that a brake line? You say it is brass. Most brass fiting are compression fitting, not all, If it is compression try giving it a 1/4 turn and see if that does it, if not then another 1/4 turn. if that dont do it get an empty gas can and a new full length of tube, drain the tank and pitch the fitting.
....David
54barnfind #847808 04/30/2012 2:26 PM
Fried - I used to live in Colorado. Now I reside in Massachusetts.
54barnfind - That photo is the brake line. I'll give the fittings another turn to see if that makes a difference. Thanks!!
Paul
