2 members (Cosmo, Wayne67vert),
43
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | I have a 56 TF that I moved the tank to under the bed. Stainless steel gas lines run along the frame to the engine compartment. I have two brass in-line connectors that are leaking fuel. I've tighten both up, but still have less of a leak. So progress, but not the total solution.
Do these connectors require Teflon? Is there something I might be missing here? Gas eating through an o-ring...???
The garage is a bit randy with the smell of gas. Momma's tolerating it... for now.
Suggestions welcome. | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Check out Permatex - they have a sealant for fuel lines. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | I have two brass in-line connectors that are leaking fuel. are they compression or flare fittings?
....David
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | A little more info, and we can help!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Not sure if there're compression or flare. Is there a way to tell without unscrewing the fittings? It would be a mess! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If it's still leaking, you gotta take it apart anyway.  Are you from Colorado? Or is the truck from Colorado?
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Is this the fitting - from your online albumn - or is that a brake line? You say it is brass. Most brass fiting are compression fitting, not all, If it is compression try giving it a 1/4 turn and see if that does it, if not then another 1/4 turn. if that dont do it get an empty gas can and a new full length of tube, drain the tank and pitch the fitting.
....David
| | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Fried - I used to live in Colorado. Now I reside in Massachusetts.
54barnfind - That photo is the brake line. I'll give the fittings another turn to see if that makes a difference. Thanks!!
