1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | What are the torque specs for the front and rear motor mounts. Book says to just tighten them down, thats seems vague to me. 1959 235 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It means an unknown number of turns with a good wrench tighter than finger tight.... and don't break it off I usually go for when it stops turning and squeaks out "OK" but if that's still to vague you might try this Torque Me
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | GM/Chevrolet seems to to do that alot on various specs. I did just what it says. Tighten it to what yoyu "feel" is right. Better, is to use the torque value for the particular bolts you are using. They can be found on the web. I use thread locker where appropriate and have even drilled for safety wire or a cotter pin.
Drew
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I don't know if you can use the torque values for the thread size because you're compressing rubber. I agree with the afore mentioned though... Just tighten till you're happy with it. It'll be fine. Jerry | | |
