0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
What are the torque specs for the front and rear motor mounts. Book says to just tighten them down, thats seems vague to me. 1959 235
It means an unknown number of turns with a good wrench tighter than finger tight.... and don't break it off
I usually go for when it stops turning and squeaks out "OK"
but if that's still to vague you might try this
Torque Me
Give me ambiguity
or give me something else
GM/Chevrolet seems to to do that alot on various specs. I did just what it says. Tighten it to what yoyu "feel" is right. Better, is to use the torque value for the particular bolts you are using. They can be found on the web. I use thread locker where appropriate and have even drilled for safety wire or a cotter pin.
Drew
I don't know if you can use the torque values for the thread size because you're compressing rubber.
I agree with the afore mentioned though... Just tighten till you're happy with it. It'll be fine.
