1 members (carbking),
77
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84551 10/22/2007 4:23 AM | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Guys I would like some input from you all. I need to know what kind of transmission to go with my 51 chevy 3100. I see a lot of 700 r4's. I would like to know everyone's opinions, and the pro's and con's. I would like to have a reliable durable automatic transmission. What is the difference in the 700r4, and the 4l80, 4l60, etc. thanks
Tony Jacques
#84552 10/22/2007 4:40 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Short answer is the 700r4 and 4L60 are the same transmission. They changed the name in later years. Add an E at the end of the 4L60 making it a 4L60E meaning the transmission is computer controlled.
The 4L80E, no manual version, are all computer controlled and much stouter than the 4L60.
What motor and rear are you planning to run, and how are you going to use this truck? My guess would be the 700r4 is adequate for most applications, but without knowing how you intend to use the truck its not possible to say for sure. If you want to run a fully computer controlled system you need one of the -E types.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#84553 10/22/2007 8:01 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I bought my 700R4 from Phoenix Transmissions in Weatherford Texas. They do an outstanding job of beefing up the tranny to whatever HP and driving conditions you will be experiencing. http://www.phoenixtrans.com/
~Jim
#84554 10/22/2007 8:18 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | tjacques: You need to consider the engine you intend to use. Some AT trannys can be adapted to inline engines and most V8's will readily work. I think it is really difficult for anyone to properly recommend something without a lot more information. It would appear that you like the A/OD transmissions but do not say. The rear end will also play a part in the best choice. Is it stock or an open rear? What ratio? Some of the people here are pretty knowledgable and can help but they will need your input. | | |
#84555 10/22/2007 9:59 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Excellent knowledge base on transmissions you mentioned and more at this website. http://www.novak-adapt.com/knowledge/transmission_gateway.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
