2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#84551 10/22/2007 4:23 AM
Apprentice
Apprentice
Guys I would like some input from you all. I need to know what kind of transmission to go with my 51 chevy 3100. I see a lot of 700 r4's. I would like to know everyone's opinions, and the pro's and con's. I would like to have a reliable durable automatic transmission. What is the difference in the 700r4, and the 4l80, 4l60, etc. thanks
Tony Jacques
#84552 10/22/2007 4:40 AM
Short answer is the 700r4 and 4L60 are the same transmission. They changed the name in later years. Add an E at the end of the 4L60 making it a 4L60E meaning the transmission is computer controlled.
The 4L80E, no manual version, are all computer controlled and much stouter than the 4L60.
What motor and rear are you planning to run, and how are you going to use this truck? My guess would be the 700r4 is adequate for most applications, but without knowing how you intend to use the truck its not possible to say for sure. If you want to run a fully computer controlled system you need one of the -E types.
#84553 10/22/2007 8:01 PM
I bought my 700R4 from Phoenix Transmissions in Weatherford Texas. They do an outstanding job of beefing up the tranny to whatever HP and driving conditions you will be experiencing.
http://www.phoenixtrans.com/
~Jim
#84554 10/22/2007 8:18 PM
tjacques: You need to consider the engine you intend to use. Some AT trannys can be adapted to inline engines and most V8's will readily work. I think it is really difficult for anyone to properly recommend something without a lot more information. It would appear that you like the A/OD transmissions but do not say. The rear end will also play a part in the best choice. Is it stock or an open rear? What ratio? Some of the people here are pretty knowledgable and can help but they will need your input.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#84555 10/22/2007 9:59 PM
Excellent knowledge base on transmissions you mentioned and more at this website.
http://www.novak-adapt.com/knowledge/transmission_gateway.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
