| | | Forums66 Topics128,140 Posts1,056,774 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I assume it is welded. Where are the spot welds located? Along the side? Can't seem to figure it out. Tony | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Your right about it being welded. In addition to being welded on the sides/ends, its also welded along the windshield opening, lots of welds!! | | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | Ok, If I remove it and get a repro dash. How do I put it back in? Drill many holes and MIG weld?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's a repro dash available??
the major welds are along the cowl flange that makes up the windshield opening, to the top flange of the dash, which is the rest of the windshield opening, first step is taking out the windshield .... can be done, but rarely is
Bill | | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | http://www.ebay.com/itm/Dash-Panel-/251026984201?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AChevrolet%7CModel%3ATruck&vxp=mtr&hash=item3a725fcd09
I guess I need to take pictures and ask what it where. It seems along the windshield is not welded but more on the sides. | | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | There's a couple dozen spot welds running across the top & down sides of the dash. There are also 2 bolts on each end up under the lower corner of the dash along w/the steering column & cowl vent braces.
An elephant is a mouse built to government specifications.
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | Ok, that seems resonable. I can use a saw and chisle and should be able to get it out. Now, putting it back in, what if I just use a epoxy with a couple of welds? I have used the epoxy on a couple of repair panels and it seems to work well. Suggestions? | | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | I personally would weld it in. When I replaced mine years ago I used a die grinder to remove it. It'll keep the metal from distorting & will be a cleaner removal. Then used a small hand grinder to remove what was left & to clean up the old weld areas. I drilled small holes around the windshield pinch weld area so I could spot weld the inner & out lips together. I also welded it solid down both sides of dash just like stock. Clamped it all together & started tack welding it from side to side.
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | My dash was shot so i replaced the whole firewall.depending on what condition your cowls are in, do they need replacing or not. Just an option to consider.
layback
| | | | | Joined: Oct 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 24 | I finally got to it and it is really not that bad at all. There is one little spot that I will have to repair. Really the truck is solid exept for the dash and floorpans. The windshield must have been leaking for years! Once the dash is out the floorpans might be easier.
t | | |
