Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Sjm, Charles in CA, Otto Skorzeny), 152 guests, and 2 robots.
Topics128,285
Posts1,058,534
Members48,490
I have a late 235 that i'm dropping into my '46. I purchased a Fenton dual intake and wonder what carbs i should use. I was thinking a couple of Carter 1 barrels. This is strickly for the street and will only have a mild upgrade in the cam. Tell me what you guys have and your experience with your set up. Cecil.........
ODSS Lawman
ODSS Lawman
I have Carters after I got sick of cleaning up leaks from my rebuilt Rochesters. Make sure you are a uni-syn tool to dial in the carbs when you get them so they will play nicely together.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I chose to run a pair of Carter/Webers on my 54 truck with a modified 1960-235.
My goal, from the onset was to build a "cruiser"...a fairly stock appearing truck that I could use on a daily basis, that would be dependable, economical and most importantly, fun to drive. Recognizing the inherent problems I'd encountered with both Rochester B's and Carter YF's over the years, I planned my build to optimize the strong points of the 235 engine and minimize the components that "seemed" to create problems. Fortunately, Langdon's Stovebolt Engineering Co. offered a carb package that fit my needs. The Carter/Weber carbs, with adaptors, linkage kit and even breathers offered bolt-on reliability with excellent tech support, should it be needed. Fortunately, the install and tuning were simple and the end result is worth every penny. Combined with the low end torque cam, a .72 BW T5, a 3.42 R&P, 29" tall rear tire,and a fuel pressure regulator set at 3.5 psi, my truck happily cruises at 65-70 mph at 1900-2000 rpms and AVERAGES 17.5 mpg. It has not missed a beat in 2500 miles since my engine build, and I don't hesitate to make a 100 mile trip to attend a show.
It's this kind of reliability that has convinced me that the Carter/Weber carb combination should be a viable option for anyone who actually wants to drive their truck. If you are interested in the process for both the Holley/Weber single and the Carter/Weber dual installation, I've documented them in my Webshots albums.
I hope this helps you with your plans.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
I got 2x1 Carter W1 on my daily 235 (see link) and it's the simplest, most reliable and best responding combination I found.
The trick is to go with 2 smaller 216 carbs for a street 235.
Larger carbs are too much and run too rich, unless you have a bigger cam and do other high-rpm mods to the engine.
I got a 216 2x1 and enlarged the intake ports to 235 size, but you can also go with 216-235 adapter rings.
You can find good cheap W1 cores all over the place and there are places online that sell quality carbs kits.
I set mine up once after installation and never needed re-adjustments. No leaks.
Gives about 18-20 mpg on the freeway with a 3.55 rear.
The smaller carbs respond just right for city driving.
The unisyn tool is alright, but inaccurate.
Get a small motorcycle carb balancer with dial.
The smallest adjustment makes a big difference.
And perfect balance between the two carbs is really noticable.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
Looks like Carter has it. Thanks guys. Cecil........
Apprentice
Apprentice
I'm using a 2x1 rochester set-up on a fenton intake. After experiencing a hesitation on acceleration I re-jetted the carbs using #58 jets, the original jets were #48. That corrected the problem. I think I'll invest in a motorcycle carb balancer with a dial readout. good luck
Although it looks like a decision has been made, I'll add this to what has been discussed.
I used Stromberg BXVD's on my 235 in a three carb configuration. They were very responsive, didn't leak and were easy to tune.
From what I read, the Carters are more mainstream, and quite easy to get parts for, but many old hotrodders used the Strombergs...maybe they knew something we don't know.
Stuart
You are right: Stromberg spells HOT ROD.
I'm using 2 Stromberg BXOV-2 for my 261.
I love that carburetor - maybe the best single barrel available for 216.
I never get rid of my Carter W1s 574s on my 235.
My favorite 'organic' looking carb and super reliable for a daily driver.
1952 Truck - 235
1948 Coupe - 261
i bought 2 of the carter webers from langdons stovebolt.....bolt em on and fired em up.......simple...
