3 members (Phak1, kades51, TUTS 59), 241 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
#844866 04/19/2012 4:32 AM
I
I Offline
After looking thru many parts catalogs and searching the internet, it looks as though there are no aftermarket suppliers who handle the rear springs for my 1960 Chevy 1/2 ton. I purchased a couple of matching coil springs at the swap meet this last weekend. (Actually, I purchased these springs to make blacksmithing tools. Truck coil springs make good punches, chisels, hot cuts, etc. because it's tough stuff..). Anyway, these springs are in good shape and the material is around 5/8 to 3/4 inch in diameter looking by eye. I would hate to cut them up if they would work on my '60. I'm thinking of matching them up to the springs on the truck to see if they are similar. If they are not, is there a way to make them work?? Also, why are 1960 Chevy rear coil springs not available, is there something special about them?? Thanks.
Iron Clad #844900 04/19/2012 7:53 AM
Summit racing sells lowering springs for the rear of a '60 C10. http://www.summitracing.com/parts/CLP-RCS6035/ Google search of the Summit supplier comes up with stock springs from: http://www.classicperform.com/Store/1960_1972_Chevy_Truck/RCS603S.htm Hope this was helpful.
5wests #844911 04/19/2012 12:05 PM
I
I Offline
Thanks 5wests, but I don't want to lower the truck. nono I'm a "stock" kind of guy...LOL.
Iron Clad #844942 04/19/2012 3:18 PM
go to a spring shop
ron
padresag #844946 04/19/2012 3:31 PM
Classic parts of america has them in stock for $100 new. Ecklers Trucks has them also.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
jon1963 #844980 04/19/2012 6:21 PM
The second link was for stock springs.....
Iron Clad #844985 04/19/2012 6:42 PM
The ones our host sells are as close to stock as your going to find however the grade 8 bolt that comes up through the bottom was hard to find locally. Hope this helps.
Dado #845125 04/20/2012 2:04 AM
I
I Offline
Thanks guys, you always come thru. Sorry 5wests, you where right, I didn't notice until I read your post again.
