1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
Hey all, I know this sounds kind of dumb, but i'm about to adjust my valves, and don't know what the cylinder numbers are on my truck. I have a 1951 chevy 4400 with a 235. Is the No.1 cylinder toward the front, or the rear?
Cylinder #1 is the one at the front of the engine.
Bill Burmeister
Not at all dumb, I ask dumber ones here. Yes #1 is in the front.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
Thanks sleevey and bill does it just go back back in order to 6 at the back?
Yes. 1 in front and sequencially numbered to the back of the engine.
H Online: Content
The next thing you'll need to know is the firing order, which determines when each cylinder fires the spark plug. Unfortunately, it's not a straight 1-2-3-4-5-6 sequence. The cylinders fire in a sequence of 1-5-3-6-2-4, which, if you'll notice, alternates from front to rear. It takes two turns of the crankshaft to fire all 6 cylinders. The simple way to do the valve adjustment is to watch the distributor rotor, and adjust the valves on each cylinder as the rotor points toward the spark plug wire going to that cylinder. Good luck!
I was taught the little ditty of remembering the firing order of a six cylinder by the eligibility of women.
15-too young 36- too old. 24-just right
Man these day 36 is looking pretty young and attractive to me! LOL.
Heck, 36 is robbing the cradle for me!
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Back when I was working on these trucks in VA, that age "ditty" would not have worked. It would have had to start with 13.
Well 36 is way too young in my book, as I have 48 y/o daughters but I like the ditty.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
