7 members (Jims46, Otto Skorzeny, dt235sd, 2-Ton, tclederman, Bill Hanlon, Millenimech), 127 guests, and 1 robot.
Topics128,191
Posts1,057,365
Members48,469
Hi,
Can somebody recommend a brand of headers to use in my 1946 pickup with a 305ci engine?
Ps.: I use the stock steering and front-end
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
I'd look for a used set of OE ram horn manifolds. Also new ones are now being made. They are short enough that your exhaust shop could clear the steering gear with a 2" pipe IMO. That is probably the biggest hurdle you have.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Orielly's has 2 1/2" ramhorns from early 60's Corvette that are about $70 each.
Anyone has expierience with the Sanderson headers ?
Cheers
Apprentice
Apprentice
I tryed a set of their block huggers on my 1950 3100 with the stock front end .they did not fit
save a camaro,run a straight axle
Why headers? They raise the underhood temperature, leak, blow gaskets, and burn plug wires. Also, there's no measureable power advantage under 3,000 RPM, even with a stock camshaft. The only time I've seen a worthwhile power advantage from headers was on a tractor-pull engine with custom built equal-length tubes on a Dodge 440, and the primary tubes were 8 feet long, going into a 6" collector. Those headers allowed us to build in a measureable torque gain at 2,000 RPM, and the HP topped out at 714 at 6,500.
At Orielly's Auto Parts you can buy early chevy small block 265 and 283 exhaust that have the dump near the back. They are made by Dorman (china) but they are pretty good castings.
I have a set of the Dorman 1963 Corvette fuel injected 2 1/2" dump ram horns. I think they are pretty nice castings. The "china" part of the casting in on the back so it cannot be seen when installed. $69
