4 members (1955 1 Series, 66flea, Peggy M, 1 invisible), 336 guests, and 5 robots.
Topics128,156
Posts1,057,017
Members48,460
I would like to keep the foot start and "3 on the tree" on my 53 3100 with a 54 235 engine. Would it be a simple fix to lower the rpm's at 50 mph? Maybe change the rear end gears or the whole pumpkin?
If you are asking if taking out an original 4-speed rear-end and replacing it with an original 3-speed rear-end, there will be no change in RPM - both have 1:1 drive in high gear.
The 3.55 Ring & Pinion conversion sold by Patrick's is one way to lower RPMs (you have a 4.11 rear end).
I do not know about a way to change the "whole pumpkin" (maybe someone else will post a reply on this). You could change out the drive-shaft and the rear-end/axle/etc (which would necessitate a change in transmission, because you would be eliminating the torque-tube).
IF you eliminate the torque tube rearend you can use the pumpkin from 55 up thru somewhere in the 60's. I used a 56 pumpkin and went from 4.11 to a 3.90. Not the best but and improvement.
...and I have read the post about the 3.55 ring/pinion set from Patricks...BUT I have read that a rearend from a Dodge Dakota already has a 3.55 rearend but not sure what year. But, as mentioned it would mean changing the tranny since the torque tube is gone.
I wish I had know about the Dakota rearend as I could have used it on my panel...if the width is good.
Just idea's here so hope some of this helps.
Hey Baby53,
Check out #843901 posted 4/14/12. This is a terrific deal & would be an easy bolt-in for you. Dickb10
The problem with using a Dakota rearend is the oddball bolt pattern. While it is 6 lug (depending on year, some ealy Dakotas are 5 lug), it is the 6x4.5 pattern. Somewhat difficult to get wheels for. The 5 lug variant uses the common Ford/MoPar 5x4.5 pattern, much better wheel availability.
Bill Burmeister
Bill, thanks for adding knowledge to this thought....it does give another "option" though.
