| | | Forums66 Topics128,161 Posts1,056,958 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | I would like to keep the foot start and "3 on the tree" on my 53 3100 with a 54 235 engine. Would it be a simple fix to lower the rpm's at 50 mph? Maybe change the rear end gears or the whole pumpkin? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you are asking if taking out an original 4-speed rear-end and replacing it with an original 3-speed rear-end, there will be no change in RPM - both have 1:1 drive in high gear.
The 3.55 Ring & Pinion conversion sold by Patrick's is one way to lower RPMs (you have a 4.11 rear end).
I do not know about a way to change the "whole pumpkin" (maybe someone else will post a reply on this). You could change out the drive-shaft and the rear-end/axle/etc (which would necessitate a change in transmission, because you would be eliminating the torque-tube).
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | IF you eliminate the torque tube rearend you can use the pumpkin from 55 up thru somewhere in the 60's. I used a 56 pumpkin and went from 4.11 to a 3.90. Not the best but and improvement.
...and I have read the post about the 3.55 ring/pinion set from Patricks...BUT I have read that a rearend from a Dodge Dakota already has a 3.55 rearend but not sure what year. But, as mentioned it would mean changing the tranny since the torque tube is gone.
I wish I had know about the Dakota rearend as I could have used it on my panel...if the width is good.
Just idea's here so hope some of this helps. | | | | | Joined: Aug 2010 Posts: 1 New Guy | | New Guy Joined: Aug 2010 Posts: 1 | Hey Baby53, Check out #843901 posted 4/14/12. This is a terrific deal & would be an easy bolt-in for you. Dickb10 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | IF you eliminate the torque tube rearend you can use the pumpkin from 55 up thru somewhere in the 60's. I used a 56 pumpkin and went from 4.11 to a 3.90. Not the best but and improvement.
Just idea's here so hope some of this helps. The problem with using a Dakota rearend is the oddball bolt pattern. While it is 6 lug (depending on year, some ealy Dakotas are 5 lug), it is the 6x4.5 pattern. Somewhat difficult to get wheels for. The 5 lug variant uses the common Ford/MoPar 5x4.5 pattern, much better wheel availability.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bill, thanks for adding knowledge to this thought....it does give another "option" though. | | |
