3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
Well hello all,
I did it again...
I just purchased another GMC truck, this time it's a Big Bolt, 1952 GMC 454-30 (179in wheel base)flatbed dump truck, bed is 96in x 180in. and in excellent shape.
Has 302 motor, 5 speed clark gear box and 2 speed electric shift rear axle. 9.00x20 tires in good shape. New battery (6v)
Do not know yet if gearbox is 5th direct or 5th gear OD :?
It does run and is drivable, last registered in 2005, I got burned on price $800.00 cash. Last used on farm 2010 to haul hay.
Dump box works, no power steering wink
Will send pix soon.
Added: http://s1253.photobucket.com/albums/hh594/GMCPic/
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
It doesn't sound like you got burnt too bad. Besides it's only money.
I
I Offline
$800.00 sounds good to me. Congrats on the buy. Can't wait for the pictures......What are your plans for the truck?
I needed a larger truck to tow my trailer and eqipment around on.
I built a heavy duty 22 foot, 2 axle flat trailer to haul my 1947 Oliver HG-42 OC3 bulldozer and my 1942 Ford 2N loader around. I just wanted to stay with older equipment of the same time period.
In other words toys;) and I could use a dump truck around my place now and then...
I will restore the truck, the dash is a mess. The rest I will know more next week when I drive the truck home.
More...
the truck has a 302 engine with one barrel carb setting on top of a governor. I am going to remove/replace the single intake manifold with a 2 barrel manifold and carb, also replace the cam and timing gears and distributor. Have the radiator recored and if the gear box is not and 5 speed OD trans, well, replace it too, I have couple sitting in a shed. If the head is not a large-port head I will replace that also.
But first I just want to drive it for awhile:0
Being a 450 series, it will have a "GMC PARTS IDENTIFICATION" tag on the back of the glove box lid that will tell you if it's a OD or not. The tag has all your trucks spec'd eng., trans., axles, info. stamped on it. It will either say 5 spd. DD, or 5 spd. OD. I own a 1952 GMC F473-30, COE.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
I
I Offline
Hey, I own a 1952 Oliver OC-3 crawler....Just bought it a couple of months ago. I'm looking for a flatbed trailer to haul it over to my property in Easter Oregon to do some prep work for a new shop I'm building. I will probably haul it behind my 1966 C60 two ton, although I don't need such a big truck to haul it, LOL......So, what does the "HG-42" stand for on your '47 Oliver?
Crusing in the Passing Lane
I'm sure all modern 302's have the large intake ports; when I got my '53 fire truck w/ 302, after I installed a 'brownie,' it wass still sort of gutless, milled the head .060", wow, what a difference, still could use Regular fuel. An economical way to get a more efficient engine.
THe HG-42 means Home Garden - 42 inch track centers. They also built an HG-30 and and HG-68. Tracks centers are for row crop distances between row center.
OK guys got the big bolt running today and drove it around the farm where it is located. Can not put it on the road yet... no brakes.
The plate in glove box says. The trans is a CLARK 205V, with CLARK front axle and EATON (electric 2 speed) Rear axle with 6.50 - 9.04 ratio. [u][/u]. Had to replace the points and coil one battery cable. Still 6 volt system with positive ground. Someone put the battery in backwards, killed the coil. Put a see through fuel filter in fuel line between fuel pump and carb. OPPS I was wrong about carb... it is a 2 barrel. Dump bed works great.
Started replacing the ignition wires. Temp gauge and oil pressure gauge work.
So biggest problem now is the brakes.
Been watching other chats about shift patterns. Mine says 1L-1H/2L-2H/3L-3H/4L-5L/4H-5H.
Shift pattern looks to be:
2 4 R
- N -
3 5 1
I think that is right.
Picture to come...
Added Photos: http://s1253.photobucket.com/albums/hh594/GMCPic/
800 sounds like a good deal to me. There is a 470 down the road from me. The guy wants 750 for it and the cab is about to fall off of it. You did OK!
