1 members (1 invisible),
80
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Will this truck handle a gooseneck? Just wondering...... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1/2 ton? one ton? original driveline with a 216 or 235? anything will handle the neck, depends on how big the goose is and what's riding on it  Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Sorry about that! She's a 3/4 ton, with a later 235 installed. I plan on making the switch to 12v for trailer brakes, and I also have a rear end "pumpkin" to up the highway speed. Just wondering if it is safe/feasible, or if I should just forget the idea. Hope to be using a 20' gooseneck. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Just remember the trucks brakes were designed in 1947 for the highway speeds of the day. For what it is worth. Jim | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | They do make front disk brake conversions & you can upgrade the master cylinder with brake booster setup. Remember saftey is the key issue, not only for yourself but for the public. I think it would be pretty cool seeing a old chevy pulling a gooseneck going down the road with all the newer trucks doing the same. Good luck. | | |
