6 members (baldeagle, Peggy M, tclederman, TexasJim50, Gray_Ghost, greenie-reddy), 65 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#843407 04/13/2012 1:02 AM
Am asking if anyone has used Kirkner automotive paints? What brand do most home painters use? Looking for primer, base, and clear coats.
Ridge dweller
ridgeview #843416 04/13/2012 1:34 AM
Just so you don't feel ignored... the guys on this site have used it all from what I've read. So what are you looking to have when your done?
Plenty of guys have gone with Rustoleum and plenty more Sherwin Williams (auto not home) PPG or Marin Senior (NAPA). Cheap to High end and back again.
I use SPI epoxy and am planning on their Red base coat and if they ever get it into production (just kidding I know its on the way) the single stage Black.
From my surfing web forums the Restoration and Kirker are mid-range but your surf board may ride differently...
FWIW I've been surfing now for over a year looking for the answer to my ultimate question of Paint Primer and the meaning of Life. In this case 42 did not compute but usually that's the one I go with. Left you wondering still?
Good.
That seems to be the end result when questions about which paint to use come up.
Give me ambiguity
or give me something else
CASO #843423 04/13/2012 1:48 AM
I used Van Sickle farm and tractor paint. I also custom mixed my own color by combining IH white and JD green. Pick a color straight out of the can if you plan to do any touch-up work later. It is really difficult to duplicate my original mix.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
FriedGreenTmater #843455 04/13/2012 3:52 AM
ChromaBase/Clear. with flattener. Have used Nason clear as well, cheaper and can not tell the difference. Primer, well depends on the part. DuPont Fill-n-sand 131S, Nason Ful-Fil are about the same. DuPont 3240S high build urethane high build primer-nason has a similar product. FYI Nason is owned by DuPont just a step down-in price anyway.
Standox spot putty is the bomb!
....David
54barnfind #843457 04/13/2012 3:55 AM
Dont forget to protect those lungs, you only got 1 set!
....David
54barnfind #843471 04/13/2012 6:19 AM
What... No Kirker users? ohwell
Give me ambiguity
CASO #843539 04/13/2012 4:12 PM
I use Nason (single stage urethane...Ful-thane) paint products with excellent results. All media blasted sheet metal gets a coat of epoxy primer before doing anything else (including plastic filler).
