1 members (Hanks custodian),
103
10
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84327 10/15/2007 4:00 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | How do you drain the rear end on a 50 chassis with the torque tube? I see a fill plug but no drain plug. The shop manual doesn't explain how to do this, it just says drain the differential. | | |
#84328 10/15/2007 4:26 PM | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Just did my 46. The bottom bolt in the rear cover drains mine. I assume yours would be the same. | | |
#84329 10/15/2007 5:56 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Good! I thought I was going to have to take it out and tip it upside down. | | |
#84330 10/15/2007 6:40 PM | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | While some gear oil will drain it is really a fill plug. In other words you fill the rear to it just runs out the hole. Jack up the front of your truck to facilitate draining and consider using a siphon. I use an old anti-freeze tester, bulb type, to siphon the old oil.
Drew
#84331 10/15/2007 8:48 PM | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I have a 50 with the torque tube, and drained mine by removing the bottom bolt in the cover as 641 Workmaster said. | | |
#84332 10/15/2007 8:49 PM | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I have a 50 with the torque tube, and drained mine by removing the bottom bolt in the cover as 641 Workmaster said. | | |
#84333 10/15/2007 8:49 PM | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I have a 50 with the torque tube, and drained mine by removing the bottom bolt in the cover as 641 Workmaster said. | | |
#84334 10/15/2007 8:53 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | If the fluid has been in there for a long time, I would consider loosening all the bolts, cracking the gasket from the surfaces and let it drain from the bottom. Then take off the cover and do a visual inspection of everything in the rear end. That way, you can make sure that there are no metal shavings in there and wipe the insides squeaky clean. It's worth the price of a new gasket and a little bit of your time. Most NAPA stores will have or can get the gasket for you in a day. | | |
#84335 10/15/2007 9:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m with Geezer. Remove the cover & check the insides. You can clean & paint the cover while it,s off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84336 10/16/2007 12:31 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Would you need a gasket for this or could you use some of that new 'gasket maker' stuff that's availble? | | |
#84337 10/16/2007 9:05 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm with the old geezer and bender, I don’t know why this is appearing so difficult, it’s pretty straight forward and probably no more than a 15 or 20 min job to pull the 10 bolts and rear cover, drain and wipe out the housing, check the gears while your in there and bolt it back together. Like they said, The gasket is only a couple of bucks and so common that they probably stock them at Wal-Mart and they were the same for all the rear-ends from 1937 to 1959 all models 3100, 3600, 3800. And no blu, just a new gasket, no blue goop needed, not a high-pressure area or anything like that you know. Seal it up and the next time someone will have to use a hammer and chisel to get the cover off! Denny Graham Sandwich, IL
Denny G Sandwich, IL
#84338 10/16/2007 1:32 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | You all make a good argument for removing the cover, cleaning it all out, and starting with fresh gear lube, and that's what I'll do. I read somewhere that it was common for the gear lube to leak past the cover bolts and a fix for this was to put a thin copper washer under the bolt heads. does anyone have a Felpro part number for the gasket? Denny, I sent you an email about Rochester carbs. | | |
