0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
This is for any of you NAPCO guys out there. Under the anvil lift block in the rear is a wedge that corrects the drive ling angle. Below is a link to a photo and measurements. The arrow points to the front of the vehicle.
NAPCO rear pinnion wedge
Information I really needed! Will help me out tremendously! Thanks for time, effort, and posting!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
It'd be better to check your driveline angles and use shims as necessary for the individual truck instead of trusting how the geometry worked out on someone else's truck.
Here's a great manual on installing driveshafts and getting the correct angles from Spicer, the last word in drivelines.
http://www.stovebolt.com/techtips/driveline/setup/index.html
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Just so you know that wedge piece is from the factory on 58-59 Chevy NAPCO trucks. Could be the same for all NAPCO's, but am only noting the year of mine.
That said, Griggs post should help dial the drive line in even more.
Yep, back when the trucks were new they might have all had the same shim.
Now 50 or 60 years later with sagging springs and perhaps some modifications you'd be smart to double check what the angles are and adjust if necessary, that's what really counts.
Grigg
---All pictures---
I can't remember if I used those or not. I think they came with my running gear. I'll have to take a look when I get home. My running gear is older than my truck.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
