0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
So my truck was originally a military truck and was painted Olive Drab. An electric company painted the truck white (not a very good job) and that white top coat appears to be peeling away in some spots revealing the olive underneath.
On other places it's not peeling away. Can I just sand the top white coat off on the entire truck to reveal the olive underneath? Or will sanding ruin both coats and I shouldn't waste my time? Any advice on this?
On this pic you can see where the paint has "worn off". Other places it's completely peeling off (I can flake off with my finger).
Pic of paint
-Troy
you won't get it looking like the original worn out olive, you'd be wasting your time, unless you take it right down to a point you can repaint it
Try a straight edge razor blade. You may be able to zip most of it off. It still won't look right but worth a try.
Ex Hall Monitor
Ex Hall Monitor
If it's pealing really bad you might be lucky enough that a good power wash might get most of it off. I'm referring to a real power washer, not the 'power wash' at the local car wash. If you try that be aware that a good power washer can do damage so tread carefully.
if you took your time and used a 220 or maybe 180 grit you might work your way down but I'd switch to an even slower grit like 320 before actually getting there and even then... What Bill said...
Give me ambiguity
or give me something else
Cool thanks guys. Probably won't waste my time right now. Maybe after I get it running and just don't have anything mechanical to fix.
-Troy
