Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Guitplayer, CuzzFuzz, 1 invisible), 38 guests, and 2 robots.
Topics128,018
Posts1,055,259
Members48,417
#842898 04/10/2012 8:57 PM
Anyone using a Weber Carb on a 250 L6? I am aware that some of you believe anything but stock on a non race engine is a waste of time and money, but I believe many engines do respond well to a little increase in intake and exhaust capability. I have used several online formulas and and come up with what I believe are some stock capacities. I believe that the 250 L6 in stock configuration can inhale between 350 and 450 cfm at 4500rpm. The stock Rochester monojet can pass a max of 350 to 400cfm. I believe a free flow air cleaner, an HEI and a set of headers with a small fuel increase will make a big difference, so how about one of the 36/38 Webers, or the 38/38 series? Anyone got one working? There is a kit for a 258 cid JEEP. That carb should work on a 250 too.
Any practical info would be appreciated. I do NOT want anything on dual carbs or 4bbls. Thanks!
Les
Carburetion specialist
Have used Webers, don't really care for them personally, but go for it if you wish.
As to CFM:
CFM (at 100 percent VE) = (RPM * CID) / 3456
CFM (at 100 percent VE) = 4500 * 250 / 3456
CFM (at 100 percent VE) = 325
Approximate VE for a basically stock Chevy 250 is .8
Therefore CFM = 325 * .8
CFM = 260
Jon.
The Carburetor Shop
I'm running a Weber 38 DGES on my 235. In my opinion its a vast improvement over the stock rochestor.
