7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | I may have a missing part, but I can't figure out how the headliner on a 1954 (full windshield) is attached above the windshield. It looks like there may be a metal strip similar to the one over the rear window but I am not sure. If anyone has a picture or instruction advise on this, I would appreciate it. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You start by installing the rear piece first (yes, there is a rear metal strip at the rear but not at the front).
Then, install the roof bow with the slot forward.
Then, install the front cardboard into the roof bow - the front of the cardboard is inserted under the windshield rubber seal.
| | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | Thank you. Guess I should have been able to figure that out.... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No harm asking. It is always nice to hear confirmation of your own thoughts, especially if it is the first time.
| | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Can I tag on here and ask about my 53 split window? If the windshield is not yet installed, can I go ahead and install the headliner and not have problems with the winshield rubber when I install it later? | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | You may be able to do it as you describe but both the windshield install and the headliner will be much easier to install windshield first and then headliner. The headliner rests on the windshield rubber until the inside windshield trim is installed.
Chuck | | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | ok thx....I'll do the windshield first | | |
