2 members (TexasJim50, Sjm),
98
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84168 10/12/2007 6:30 PM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | On my '54 GMC 248 the valve cover has a oil fill hole, (cap missing). I've noticed, looking at pictures of other engines on this site and elsewhere, some of these stovebolt engines have an oil fill in the valve cover and some don't. Is the oil fill in my '54 standard or an option or is the valve cover perhaps off of something else? (maybe a newer engine or something like that?) Also, since I need a cap for this is it supposed to be a breather type cap or just a solid cap? Also, there's a hook up for a hose right next to the oil fill on the valve cover. Is this supposed to go to the air cleaner or where? Thanks in advance! (again) Oil fill hose on valve cover | | |
#84169 10/12/2007 7:18 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The logo on that valve cover indicates it is a later cover. The oil cover would be non-vented. The vent would have been plumbed to the intake manifold | | |
#84170 10/12/2007 8:18 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Have you confirmed the engine serial number matches a 248? That later valve cover would make me wonder if maybe its a 270.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#84171 10/12/2007 9:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84172 10/13/2007 3:57 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Originally posted by OldSub: Have you confirmed the engine serial number matches a 248? That later valve cover would make me wonder if maybe its a 270. Yeah, I'm beginning to wonder myself. I was told that it came out of a '54 GMC but I suppose it could be possible that it was a later replacement engine. I'll have to check the numbers to be sure. Can someone direct me to where to look and how to interpret them? | | |
#84173 10/13/2007 4:07 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | First 3 stamped engine number digits are the displacement. | | |
#84174 10/13/2007 4:47 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Well, I went out in the garage and looked and the number on the block, to the rear of the distributer, is N (or A) 37501 7OAL (Near as I can tell through all the grease) Also, right below this number is stamped in smaller numbers "248". | | |
