Brrrr
place holder
4 members (1954gmc9314, Hotrod Lincoln, greenie-reddy, 1 invisible), 115 guests, and 4 robots.
Topics128,272
Posts1,058,419
Members48,485
#84168 10/12/2007 6:30 PM
On my '54 GMC 248 the valve cover has a oil fill hole, (cap missing). I've noticed, looking at pictures of other engines on this site and elsewhere, some of these stovebolt engines have an oil fill in the valve cover and some don't. Is the oil fill in my '54 standard or an option or is the valve cover perhaps off of something else? (maybe a newer engine or something like that?) Also, since I need a cap for this is it supposed to be a breather type cap or just a solid cap? Also, there's a hook up for a hose right next to the oil fill on the valve cover. Is this supposed to go to the air cleaner or where?
Thanks in advance! (again)
Oil fill hose on valve cover
#84169 10/12/2007 7:18 PM
The logo on that valve cover indicates it is a later cover. The oil cover would be non-vented. The vent would have been plumbed to the intake manifold
#84170 10/12/2007 8:18 PM
Have you confirmed the engine serial number matches a 248? That later valve cover would make me wonder if maybe its a 270.
#84171 10/12/2007 9:33 PM
Riding in the Passing Lane
I,d use the vented cap.
1972 Chevy c10 Cheyenne Super
#84172 10/13/2007 3:57 AM
Quote
Yeah, I'm beginning to wonder myself. I was told that it came out of a '54 GMC but I suppose it could be possible that it was a later replacement engine. I'll have to check the numbers to be sure. Can someone direct me to where to look and how to interpret them?
#84173 10/13/2007 4:07 AM
First 3 stamped engine number digits are the displacement.
#84174 10/13/2007 4:47 AM
Well, I went out in the garage and looked and the number on the block, to the rear of the distributer, is N (or A) 37501 7OAL (Near as I can tell through all the grease) Also, right below this number is stamped in smaller numbers "248".
