6 members (MaxStewart, MikeE, ShopRag, 59 fleet, DougH6100, Hotrod Lincoln), 141 guests, and 3 robots.
Topics128,128
Posts1,056,661
Members48,450
I while back I switched out the Rochester on my 60 235 with a Carter YF 2101S. The switch was strait forward with the exception that the intake manifold studs are a little to long, and without a couple of extra gaskets the passenger side stud comes in contact with the carb body.
So my question, should/can this be solved with a carb spacer or do I need to replace the intake manifold studs? If a spacer, maybe someone has a vender source?
Thanks much,
-Chris
1953 Chevrolet 3100
Do you have the spacer installed?
I had no spacer under the Rochester, just a gasket..Should there have been one?
1953 Chevrolet 3100
Yes, and they are available from all of the vendors.
Perfect.
Thank you Don.
1953 Chevrolet 3100
